and the build begins, but first i need some help
Old 04-29-2012, 08:02 PM
TEXASx2000xMUSTANGx
TEXASx2000xMUSTANGx's Avatar
Default and the build begins, but first i need some help
just got my car back from having comp cam 270's put in, and thanks to the shops advice on putting in new lifters, my motor sounds like complete s***. above 60 mph, idk if its the lifters (cause idk much about this kinda stuff) but something sounds like hundreds of little things wanting to get out from under my valve covers. Either above 60 mph or ANY time i stomp on it, it automatically starts in and annoys/scares me. Can someone try and help explain this to me? cause im still learning all about the internals of the 4.6
Plus im planning on doing forged internals from d.s.s. racing, any good/bad things about em?
-overall, i need advice on where to go from this point. i have full bolt on's and, as i mentioned, brand new installed comp cams and its just not cutting it for me.
TEXASx2000xMUSTANGx is offline
Old 04-30-2012, 12:55 AM
Romer
Romer's Avatar
I think you need to get it to a tuner before you get on it again.
Romer is offline
Old 04-30-2012, 06:18 AM
uberstang1
Chupacabra
uberstang1's Avatar
anyone you can post a video? are they ticks? there really shouldn't be noises like you are describing.
uberstang1 is offline
Old 04-30-2012, 08:37 AM
dwtjr3
dwtjr3's Avatar
+1 on the video. You shouldnt hear any ticks at all. Hope its not valve tap
dwtjr3 is offline
Old 04-30-2012, 10:24 AM
Old Mustanger
Old Mustanger's Avatar
If your hydraulic lifters/rockers were not filled with oil before installation they would make quite a racket until they pumped up, but that shouldn't last more than a few minutes of running time. This would be noisier at lower RPMs and quieter at higher RPMs.
It could be noisy if one of the cams was a tooth off on the timing, but that is unlikely from a good shop, but mistakes do happen.
It could be detonation, if it is, you have to get to a tuner quickly before you do damage to your internals. This should be quiet when the engine is not loaded but noisier when the engine is under load (accelerating). This might be the most likely possibility.
Maybe these cams require a special tune?
I don't know anything about the engine you are running.
Is there different combinations of rocker arms & valve heights available for it?
Is there a special rocker required for your particular cam?
If it isn't detonation and it isn't cam timing, then there is either an excessive gap between the cam & rocker arm or the rocker arm & valve stem.
I would contact the Customer Service dept of your cam manufacturer to start, they should be able to help you with a list of most-likely to least-likely possibilities.
Old Mustanger is offline
Old 04-30-2012, 01:33 PM
TEXASx2000xMUSTANGx
ill post a video as soon as i can and we'll go from there. But as of now im not driving it anywhere until i can get an idea of whats going on.
Old 04-30-2012, 01:46 PM
Old Mustanger
Very good plan!
Old 04-30-2012, 02:17 PM
TEXASx2000xMUSTANGx
i cant get a decent sound clip for the life of me so tried my best to find a SIMILAR sound on youtube and this is what i came back with.
http://www.youtube.com/watch?v=wwCAegAB7p0
http://www.youtube.com/watch?v=dwodS...eature=related
Old 04-30-2012, 02:24 PM
Lokota
Lokota's Avatar
piston slap! mine sounds just like that!
Lokota is offline
Old 04-30-2012, 02:26 PM
Lokota
Lokota's Avatar
btw mind sending me some pics of ur car? the sig looks sexy and im trying to make a desktop background with several mustangs
Lokota is offline
Quick Reply: and the build begins, but first i need some help
