Battery power slowly draws over time... - Page 3 - MustangForums.com
Old 10-08-2015, 02:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Old 11-18-2013, 08:11 PM   #21
fullmonte60
fullmonte60's Avatar
i plan to hook the meter back inline and unplug the amps and see if the draw goes away again. I've kept the fuse out and the battery voltage hasn't dropped a bit in over 2 days. i'll post something Friday or Saturday.
fullmonte60 is offline   Reply With Quote
Old 11-24-2013, 08:10 PM   #22
fullmonte60
murphy's law rearing it's head for me this w/e. I removed the rear seat for easy access to the amps. put the 25a fuse back in then connected the meter inline but I didn't see any draw. I must've blown the amp fuse in the meter last weekend. I can see voltage. I left the fuse for about 12 hours and saw the volts drop about .2 i'll get another fuse for the amp and try again.
Old 12-08-2013, 07:58 PM   #23
fullmonte60
haven't had the chance the past couple of weekends but I have the power meter working again. was at that crazy Ravens game today...wow!
Old 12-15-2013, 08:35 PM   #24
fullmonte60
it turned out to be the left rear amp. unplugged that and the draw went away. stereo still sounds good. I think I found the bad amp. put my power meter inline and saw a draw of .13, put the fuse in for the radio and it jumped to .31., removed the cable from the amp behind rear seat on driver's side and it went back down to .13. then unplugged the passenger side amp and no change so I plugged that back in. I left the driver's side amp unplugged and the radio still has volume. i'll know for sure in the a.m. when I re-check battery voltage.
Old 12-21-2013, 05:58 PM   #25
fullmonte60
let it sit for the week. battery volts dropped just .2 and it fired up this a.m. what a freakin' relief...lol
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
72 Cobrajet, not a Mustang though SSRFUZZY Members Other Vehicles 6 01-06-2016 09:22 PM
seems like car doesn't have enough juice to turn over logan409 4.6L (1996-2004 Modular) Mustang 10 09-26-2015 08:43 PM
How to Replace Your Ford Mustang Power Door Lock Actuator MustangForums Editor General Tech 0 09-25-2015 07:58 PM
87 4cyl battery drain issue wilsonro 4 Cylinder NA and Turbo 0 09-11-2015 08:13 AM
1999, battery, body, draw, drive, fox, gem, mustang, powered, problem, stick, v6, vbulletin, voltage, welding
