supercharger belt slippage damage ?s
so i'm ready to up the boost on my vortech supercharger. going from 9lbs to 16lbs i'll be good with my current stock belt set up. but... i know the supercharger can push more and i know my motor will take it. the problems belt slippage right now and i want to know what kind of affects can belt slippage cause like, loss of boost, damage to the motor, ect...
any input would greatly help me cause i'd love to push that 20lbs out of that vortech.
I fail to see how plugs will foul out from being rich, if the belt slips that means its not gonna push the air it should be, but ultimatley that means that same lost air isn't going to make it to the mass air flow meter, so I don't see why it would be spraying extra fuel because.
Fuel is also controlled by RPM, same rpm minus the boost that is supposed to be there makes it run rich. I had belt slip problems when I had a 6 rib and you can see the A/F go super rich on the dyno graph. That is how you ID belt slip.
You can see on my old sheet I had belt slip at the end of the pull. You can see the hp get rough and the A/F go up.
Sorry man but you got to pay to play. 8 rib set up is about $800 with an O/D crank pulley and a thump r tentioner is around $300. Those are what you will need to keep belt slip at bay at 16 lbs.
If you don't want to spend that, run less boost and carry an extra belt around in the trunk.
