5.4 32v swap fuel delivery
Old 05-10-2012, 01:14 PM
The Pirate
The Pirate's Avatar
Default 5.4 32v swap fuel delivery
ok, like the title says im looking to swap a navi engine into my 02 gt and i have a pretty good idea of what to do except for the fuel system.
here are my planned specs:
stock cams since i've read they are the same as 03/04 cobra ones
extensive port and polish of the heads
cobra or mach 1 intake
frpp shorties
so my questions are will the stock fuel rail be enough? what size injectors should i run? and will a svt focus fuel pump be able to handle it?
thanks in advance for the help
The Pirate is offline
Old 05-10-2012, 02:03 PM
JC316
JC316's Avatar
With that, I am pretty sure your stock pump will handle it, so an SVT pump will definitely handle it. Stock fuel rail should be fine and I would like to think the stock injectors would be fine, but you could probably get some 42lbs ones if you like.
JC316 is offline
Old 05-10-2012, 05:45 PM
oxfordgt
oxfordgt's Avatar
Stock fuel system will handle that just fine.
oxfordgt is offline
LiquidDrink
09-29-2015 10:06 AM
foxtrot
09-29-2015 06:32 AM
Brett Ludlow
09-23-2015 06:59 AM
SteelerNation82
09-16-2015 07:11 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: 5.4 32v swap fuel delivery
