fuel delivery problems
i can't get my mustang to stay running and when i plug in my obd 2 scanner its shooting code p1233 saying the fuel pump driver modual isn't working and theres low fuel pressure in the fuel rails. so far i've dropped the fuel tank to replace the strainer filters, the fuel pump canister strainer filter was extrmely dirty and i'm hoping thats the source of my problem. after that i blew out the fuel lines with an air hose, and tomarrow i'm going to hook up a new inline filter and hook everything back up. does anybody have any other suggestions of what i can do to make sure this solves the issue?
I would start looking at the fuel pump itself, with the new filter and strainer I would put a manual FRG on the shreader valve and see what the pressure is at the line, if its still low the only thing really left is the pump.
Don't wait like I did. just replace the fuel pump now...
The fuel pump I got in there now is still fairly new. And I'm starting to think it might be the tune. I'll get a gauge for the fuel rails to if its fluctuating to much. I just don't think it's the fuel pump even though it could be the issue. I just never really put that much strain on it
lobout thats some good info though. my idle is set at 1000 rpm and when the problem occurs it will jump from 400 to 1000 back and fourth until it dies. is this similar to what was going on with your car? i don't want to believe its the fuel pump (mainly because i don't have $350). i'm bringing the car to the dyno this saturday for a proformance tune and i'll see if they got any ideas. but i think the current tune on the car is the issue but i'll find out saturday
Yeah that sounds about right. When mine would act up at idle it would jump around the same range from 1000 rpm to 400 rpm. It was the oddest thing which is why i think it took so long to figure out what was going on. It would happen at random times, the car would be fine for days, then it would show the symptoms, I let it sit for 10 minutes or so, and then it would be fine again. I did a lot of research after the fact, and found out that this was a known problem with the 2k stang. It is the only year that they used this particular fuel pump because of this issue. Which is the reason the thing is so damn expensive. Ford should have issued a recall on it, but in their ultimate wisdom they just burried the problem, as they had already moved on to a new pump and most of the problems did not start appearing until the pump had 30k+ miles on it.
did you happen to run a scanner or something threw your obd2 port and get that p1233 code by any chance? apperntly the fuel pump driver module regulates the fuel pressure in the fuel rails and i could see that being the problem as well. eather way tomarrow i'm dropping the fuel tank again just to check for shorts and other electical monkey bissnass.
