Rear end and Tranny fluid change
Just picked up an 03 Mach 1 looking to change the rear end and tranny fluid but not exactly sure the proper steps. Can anyone please point me in the right direction with a step by step, how to. Im sure someone has posted an do it all know it all on this process.
Thanks!
Thanks!
auto or stick, its pretty straight forward for a manual trans and a rear end, remove drain plugs and fill plugs on both, re install drain plug, fill trans and rear untill fluid level reaches the bottom of the fill holes, re install fill plugs.
Sorry yeah it's a stick. Well that seems pretty straight forward, thanks! Any reccomendations on which fluids I should use anything I shoul look for other than the obvious metal shavings. Also are there any additives I need to add. I remember with my 93 5.0 used to have to add a limited slip additive.
A much easier way to fill the trans is to remove the shifter and fill from there. Using the fill plug can be a bit of a pain. It takes 3.2 qts of Mercon V atf; Mobil 1 synthetic atf and the GM synchromesh atf are also great fluids for it.
Changing the diff fluid isnt hard. Just remove the bolts holding the cover on and remove the cover, slowly, witha drain pan underneath it. clean gasket mating surfaces, install cover with new gasket. Fill with gear lube of your choice, about 3 qts, (i like mobile synthetic) add friction modifier and done.
Thanks to everyone who chimed in on this! I changed the rear end and tranny fluid this past weekend. I used Royal Purple for both. Everything went smooth and everything is running smooth as well!!!!
Thanks again!!!!
Thanks again!!!!
91StangOwner
08-20-2015 11:34 PM
Greyshot
08-15-2015 03:32 AM
92 5.0stang
08-13-2015 06:46 AM
