Having problems installing Raxiom Switchback Turn Signal Conversion Kit w/ Resistors.
Old 06-03-2012, 08:07 PM
GriffinGT
GriffinGT's Avatar
Question Having problems installing Raxiom Switchback Turn Signal Conversion Kit w/ Resistors.
Hey,
I purchased Raxiom Switchback Turn Signal Conversion Kit w/ Resistors from AM and also the Relay that slows your tail lights down. I was told if you purchase the relay you do not need the resistors. Well the problem is when my Head lights are on and i turn my blanker or Hazards it still has the white light on dim. I tried to install the resisters and the same problem recurred. Not 100% if the resistors were installed correctly because there is no instruction. Is this normal for theses lights or have I done something wrong and if so I need help.
Thanks
GriffinGT is offline
Old 06-05-2012, 10:13 AM
freyes
freyes's Avatar
I installed switchbacks in my HID retrofit headlights. My retrofitter can be reached at
sickhids.com. Email him, and he should be able to answer your questions. Pics of your resistors, relays and bulbs would also be helpful. If you could show how you wired these switchbacks up, Maybe I can help.
freyes is offline
Old 06-05-2012, 01:20 PM
stevednmc
stevednmc's Avatar
What white light are you talking about exactly thats staying on dim? Headlights? parking lights? Front rear what?
stevednmc is offline
Old 11-28-2012, 11:13 PM
JayBeStangs94
JayBeStangs94's Avatar
You ever figure it out GriffinGT?
JayBeStangs94 is offline
Old 11-29-2012, 10:24 AM
GriffinGT
GriffinGT's Avatar
No I never did. I called AM and they sent me another pair but I had the same problem. I believe I was doing it wrong but there are no instructions. I sold what I had and washed my hands from the issue. The people I sold the lights to had no problem putting them on. I did not ask how they did it.
jrh2592
01-15-2014 12:10 PM
Boostaddict
07-14-2012 11:35 PM
saleen0101
09-22-2011 09:53 PM
saleen0101
09-22-2011 01:07 AM
Quick Reply: Having problems installing Raxiom Switchback Turn Signal Conversion Kit w/ Resistors.
