Rough idle after PI intake swap
I just swapped out my old plastic manifold because it finally sprung a leak. Everything fit back together nicely but once i started it back up, the idle was a bit rough. Sounded like i put cams in it. It also feels as if its bogging down while im accelerating through all gears. I double checked all the lines to make sure everything was connected correctly. Not sure where else to look without tearing it all back down again. Any suggestions?
UPDATE: My check engine light came on today. It threw the cylinder 5 misfire code. Hoping its only a coil or the spark plug. But I have replace the coil less than a year ago and the spark plug a month ago. But the reason I had to replace that coil was because I had a blowout on that cylinder. Stripped the thread and all. Had to put an insert in. But in wondering why this is happening now after the intake install. And yes it was new.
zanemoseley
09-06-2015 12:58 PM
