Car shuts off while cruising to a stop in neutral
You have obviously never taken off an EGR valve before--if it is clogged or sticking it will be filled with the nastiest burned/hardened up stuff you have ever seen. Concrete would be easier to clean out...
That said, I would disconnect the battery for 5-7 minutes and clear it out.
In fact I do this at the start of what passes for "seasons" down here. The PCM would re-learn things for the change in seasons, however it relearns much more slowly than it initially learns--resetting the KAM forces it to re-learn...
Cooler air is more dense than warmer air; but as the MAF (Mass Air Flow) sensor measures the mass of incoming air, rather than the volume, that is not a huge factor. IAT (Intake Air Temperature) is used in fueling calculations however it has more impact on ignition timing.
We have 2-1/2 seasons here in NE Florida. Nice (the 1/2 part), hot, then Friggin' HOT, and back to hot for a while before returning to nice.
Accufab TB
I put Accufab TB on my 4v and have had problems w/ car shutting off when coming to a rolling stop if I wasnt in gear. I replaced almost every sensor and part thats been mentioned in this post with no good results. I searched and searched threads and websites for the answer, and in a post (cant remember where i read it) someone wrote about Accufab TB throttle plate being off centered. That it was letting air blow by the throttle plate even tho it was shut. The way to fix the problem was to take your inlet tube from airfilter to TB off to gain access to the butterfly. then loosen the little allen bolts holding butterfly on the center bar rod. It should shift into place where it needs to be. Just be careful and not loosen bolts all the way that they fall out!!! I did this procedure and it has helped my rolling stop idling problem. But when my TPS was bad, setting at idle it would stay idled up a few seconds before it would drop to normal idle after giving it fuel.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
