CV joint noise?
CV joint noise?
My car has recently started sometimes making a grinding noise when turning slowly left or right, or coming to a stop downhill. This started happening awhile after I had the car lowered on HR SS springs and Eibach prokit shocks/struts (also with a MaximumMotorsport set of caster/camber plates). I also noticed that on slightly bumpy roads, the car makes squeaking noises a lot (which I'm assuming would be the shocks?)
Does this grinding issue seem like the cv joints? Wondering if anyone else can relate so I know I'm looking in the right direction.
My front left wheel bearing does make a lot of noise on the highway, but the wheel bearing doesn't make this sort of grinding noise at slow turns as I described do they? Under the car the joint 'looks' fine, dust boot has no tears
I'd say it's your bearing, they grind like mad as they go out. I just did the front pair on my '98. Took about 15 mins each side. I actually replaced the entire hub, it's only acouple bucks more, you get 5 new studs to work with instead of the old naste studs that tend to have messed up threads anyway - and you don't need to worry about pressing the bearings in (or knocking them out). Just make sure you have a 36mm socket and big tq wrench. The main nut goes on with 200ft/lbs and it feels like about twice that to take it off. LOL
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
KingRando
10-02-2015 08:06 AM
