sct live link does not work?
i get this stupid unhandled exeption error everytime it opens and the program does not function. i click "more details" and i get this:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'System.Data.Linq, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file specified.
File name: 'System.Data.Linq, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
at SCT.Communications.TCP.TCPClient..ctor(Int32 MaxMessageSize, Int32 MaxQueuedMessages, String MessageHeader, String MessageFooter, Object OnDisconnect)
at SCT.Jungo.Client.SCTJungoClient..ctor(Object OnConnected, Object OnRequestDevice, Object OnRequestDevFilled, Object OnDevAttached, Object OnDevDetached, Object OnDevInUse, Object OnDevNotInUse, Object OnDevFree, Object OnDevNotFree, Object OnDisconnect, Int32 MaxMessageSize, Int32 MaxQueuedMessages, String MessageHeader, String MessageFooter)
at Sct.XC2LiveLink.SCTCommunications.StartJungoClient ()
at Sct.XC2LiveLink.XC2LiveLink.XC2LiveLink_Load(Objec t sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at Sct.XC2LiveLink.XC2LiveLink.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
livelink
Assembly Version: 6.5.0.0
Win32 Version: 6.5.0.0
CodeBase: file:///C:/Program%20Files/SCT/LiveLink%206.5/livelink.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Sct.Common
Assembly Version: 1.0.44.0
Win32 Version: 1.0.44
CodeBase: file:///C:/Program%20Files/SCT/LiveLink%206.5/Sct.Common.DLL
wdapi_dotnet1011
Assembly Version: 10.1.1.0
Win32 Version:
CodeBase: file:///C:/Program%20Files/SCT/LiveLink%206.5/wdapi_dotnet1011.DLL
SCT.Communications
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/SCT/LiveLink%206.5/SCT.Communications.DLL
SCT.Jungo.Client
CodeBase: file:///C:/Program%20Files/SCT/LiveLink%206.5/SCT.Jungo.Client.DLL
SCT.Database.ADO
Assembly Version: 1.1.2.0
Win32 Version: 1.1.2.0
CodeBase: file:///C:/Program%20Files/SCT/LiveLink%206.5/SCT.Database.ADO.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
i try to use the updater and i get another error message which i cant understand. does anybody know what the deal is? i am not that great at computer stuff like this and i am completely confused! i spent 420$ for the damn thing and i cant even get it to work!!
mscorlib
livelink
System
System.Drawing
Sct.Common
wdapi_dotnet1011
Win32 Version:
SCT.Communications
SCT.Jungo.Client
SCT.Database.ADO
enabled.
For example:
<configuration>
</configuration>
It looks like you got a corrupted install. There is a file that your live link program is looking for, and it cannot find it. Do a search for system.data.linq. I would just uninstall the live link program, and clean up all the registry links, and download a new live link.
Seems pretty clear-cut to me..
Have you updated your .net runtimes? I would simply do this through windows update (in the control panel if you use Vista or Win7, using the IE browser if in XP, its under the tools menu dropdown)
It's looking for the .net 3.5 namespace definition, and not finding it.
http://www.microsoft.com/net/download
Code:
System.IO.FileNotFoundException: Could not load file or assembly, Version=3.5
Code:
It will likely work right after you update the .net framework without re-installing live link. I assume this is XP then? Do the 3.5 one that should list in the updates(optional section I believe). I'd suggest doing them all when you get time, likely piecemeal as something is likely to go wrong should you try to do them all at once depending on how long it has been since you've updated. Both optional(minus language packs) and critical.
