steering question
Old 08-29-2012, 12:17 PM
rafacalz
rafacalz's Avatar
Default steering question
Normally my car doesn't have much play in the steering wheel, but a few days ago it decided to have a huge amount of play about 2" worth. I topped off the power steering Fluid, it helped a little but not much. Im thinking maybe the rack and pinion has gone bad. What do you guys think?
The car has been lowered for about a year and a half
rafacalz is offline
Old 08-29-2012, 12:21 PM
uberstang1
Chupacabra
uberstang1's Avatar
Few things to check out here, Tie rods and the steering shaft first. The shafts on these cars use a rubber rag joint, which can fall apart, stretch especially if you have longtube headers that move heat to it. ITs faily easy no notice if you have a buddy to turn the wheel why you check. If the tie rods and and shaft turn out the next culprit I would imagine is the rack itself. Does it leak?
uberstang1 is offline
Old 08-29-2012, 01:31 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
^+1. The only way to find out what's up is to have someone you trust (because the engine needs to be running) move the steering wheel back and forth while you observe the steering gear and see what isn't moving that should be--or what is moving that shouldn't be...
cliffyk is offline
Old 08-31-2012, 12:39 AM
SXGT
SXGT's Avatar
is it hard to access the steering gear? I need to be looking for a tutorial on this. also OP do you hear a poping sound sometimes coming from the tie rod?
SXGT is offline
Old 08-31-2012, 07:22 AM
uberstang1
Chupacabra
uberstang1's Avatar
Not hard at all the rack is bolted direcetly to the k frame, theres an access slot in the k frame ro remove the punch bolt with holds the shaft to the rack.
Old 08-31-2012, 09:02 AM
rafacalz
rafacalz's Avatar
thanks everyone!! im going to do that today, i haven't seen a fluids on the ground, but i really wont know till i get under there. plus my car is probably mad at me or something because the throwout bearing went out yesterday afternoon, ill have my hands full this weekend lol
rafacalz is offline
Old 08-31-2012, 09:03 AM
rafacalz
rafacalz's Avatar
and no, i haven't heard any popping noise
rafacalz is offline
lincolnshibuya
12-08-2020 01:49 PM
allenmaty
09-24-2015 09:17 AM
stark777
09-21-2015 12:46 PM
BOBCATJACK
09-14-2015 02:18 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: steering question
