what could cause this? vid inside
Old 10-01-2012, 10:42 PM
69MustangCoupe393cid
69MustangCoupe393cid's Avatar
Duplicate post.
69MustangCoupe393cid is offline
Old 11-01-2012, 09:43 PM
Ok guys I'm still trying to figure this out. I've changed my fuel pressure regulator, fuel pressure sensor, the fuel filter is new and installed correctly and I dropped the tank to look and be sure all connections were good and they are. Pump only has 10k miles and seems to make good pressure. Basically I have this horrible hesitation anytime I let off the throttle and then jump right back on it aka shift and hit the next gear and she bogs. You can see the fuel pressure drop below 30 psi which I'm assuming is causing this. Is there some valve or something that's supposed to keep the pressure held at a minimum of 30?
Old 11-03-2012, 06:39 PM
At the chance of talking to myself I'm going to ask anyway. Could this be caused by a faulty or failing Fuel pump driver?
PaulH2
20
01-31-2016 09:48 AM
breaking
10-02-2015 01:27 PM
69Volunteer
09-30-2015 10:39 AM
GLOCKer
09-28-2015 07:36 AM
ctgreddy
09-20-2015 08:35 PM
Quick Reply: what could cause this? vid inside
