o/r MAC ProChamber SCT tuning help
I just had an o/r MAC ProChamber h pipe installed, with my previous super 40 series american thunder catback. The car has a very strong exhaust smell coming through the bottom of the car, from the manifold area during idle. It's actually bad enough that it's like gassing myself in a garage. I do have an SCT SF3/x3 flash tuner since I had 4.10 gears put in. I was told since the cats were deleted I'd be running rich.
So I was wondering how I can adjust these parameters myself with the SCT tuner? There is only a WOT Air/Fuel ratio where I can adjust to make it .6% (increments) leaner or richer. However, it's under WOT category so does this mean this will affect the air/fuel under WOT or will it affect me under idle too?
I just needed some input from you guys before I start making things worse
If there actually is "very strong exhaust smell coming through the bottom of the car" then you have an exhaust leak--which can make the engine run rich if it is before or near the front O² sensors.
The exhaust flow is not one homogeneous stream, but rather a series of pulses created by each exhaust event. These pulses have a head, body, and tail; each with different characteristic, with their pressure relative to the outside world being the most significant.
- The head is at a pressure higher than ambient, when it passes the "leak" the gas flows out into the world; but the chemical composition of the gas in the pipe remains unchanged;
- The body is at or close to ambient pressure. When it passes the leak nothing happens as it and the ambient pressure are nearly the same--the chemical make-up of the gas in the pipe remains unchanged;
- The tail is at less than ambient pressure (nearly a complete vacuum), and when it passes by the leak it sucks in ambient air--changing the exhaust gas chemical composition and making it appear "leaner" to the O² sensor;
This makes the PCM believe the mix is lean and it will wrongly make the mix richer to compensate. A big or close enough leak can cause the sensor response to slow or even appear "stuck" at lean.
Here's the issue with the leak, the header has a little gap where it meets the midpipe. The drivers side came with a flared adapter, a cylinder sleeve, which helped cover that gap. However there isn't one for the passenger side. Any ideas on how to deal with this? I contacted American muscle, but they just sell the kits so I will have to contact MAC.
The passenger side is a flat flange connection that needs a gasket, unlike the ball and socket connection of the driver's side that does not.
Some aftermarket mid-pipes are not made well and need two gaskets to seal up the flanges--the engine will not run properly until this leak is fixed.
$6 to $8 at any FLAPS (Autozone $6.99)...
Thanks man that's exactly what I needed to know. Right now I'm getting this sound, is this the exhaust leak or something else? I have not heard this sound before except for when I had my 4.10s first installed and tuned. After the tune it produced this sound so I returned to stock, and retuned and it went away. But now it's there tune or not.
jwog666
12-27-2021 08:09 PM
