wheel Gap of 2000 mustang gt - Page 2 - MustangForums.com
Old 11-02-2012, 05:46 PM   #11
jrp1588
Maybe subjectively it could look differently I suppose, optical illusions and whatnot, But given the same outer diameter tires, the actual wheel gap will be the same.
jrp1588 is offline   Reply With Quote
Old 11-06-2012, 05:56 PM   #12
UPRSharad
Sponsor
UPRSharad's Avatar
The outer diameter of the tires will affect the fender gap. Your tires should be close to 26" tall.
UPRSharad is offline   Reply With Quote
Old 11-07-2012, 11:59 AM   #13
AMWill
Platinum Sponsor
AMWill's Avatar
OP,
I think you'll like the Eibach Sportline Springs for your 18" wheels. To help you get a better idea what your stance will look like, check out this other New Edge Mustang equipped with the same springs.
Hope this helps your decision. Let me know if you have any questions!
Shane
AMWill is offline   Reply With Quote
Old 11-07-2012, 03:15 PM   #14
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
SHane,
Would you recommend the same for a 17" wheel? I saw on the link that you posted that there were some Ford Racing lowering springs too. How much of a drop will those give?
Thanks.
fastbackford351 is offline   Reply With Quote
Old 11-07-2012, 05:49 PM   #15
jrp1588
The wheel doesn't matter. It's the outer diameter of the tire that matters.
Old 11-08-2012, 09:24 AM   #16
00'mustangGT
00'mustangGT's Avatar
Thanks Shane but I already bought your sr performance springs a while ago but thanks for the pic the 1.5 in drop should look good with my tires.
00'mustangGT is offline   Reply With Quote
Old 11-09-2012, 04:17 PM   #17
AMWill
Platinum Sponsor
AMWill's Avatar
Quote:
Originally Posted by fastbackford351 View Post
SHane,
Thanks.
We actually have a few FRPP lowering springs available. If you click on the item and go to the "specs" tab, it will tell you how much they'll lower your car front and back. Let me know if there's anything else I can do!
Shane
Quote:
No problem! The SR Performance springs are great budget spring as well. We've installed them on a few of our Mustangs here at AM. Plus, I've heard nothing but good thing from our customers too. I'm sure you'll enjoy them!
Shane
Old 11-10-2012, 10:33 AM   #18
00'mustangGT
Quote:
Originally Posted by AMShaneLesky View Post
OP,
Shane
Just a quick question Shane. I'm about to order the deep dish fr500s and tires to go with them. How does the mounting process go and would I have to install my own valve stems or do you provide everything so I can put them right on my car when I get them.
Old 11-10-2012, 12:25 PM   #19
Seabee1993
A quick note on staggered wheels, tires are directional, so if you have them rotated regularly, they have to take the tire off the wheel to rotate. While it looks great, it's just a PITA.
Seabee1993 is offline   Reply With Quote
Old 11-11-2012, 09:15 PM   #20
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Quote:
if you rotate your tires you obviously arent driving hard enough...
sn95_331_GT_ yellow is offline   Reply With Quote
4.6 2v to 4v swap help mmbrown 4.6L General Discussion 2 09-08-2015 01:29 AM
Running lean 01blackgtconv New Member Area 9 08-14-2015 04:50 PM
Swap questions $A_Money$81 V6 (1994-2004) Mustangs 1 08-11-2015 01:30 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 09:22 AM
Running Lean 01blackgtconv 4.6L (1996-2004 Modular) Mustang 2 08-10-2015 01:25 PM
