rear upper control arm question...
Do I need a special tool to remove/install a bushing on the rear upper control arm? I was under there changing the diff oil and noticed that the bushing that connects the rear upper control arm to the rear sway bar has warn through to the metal.
Any idea for a good place to pick one up?
Polyurethane vs Solid???
Here are some good instructions from Baseline Suspensions on bushing removal. Not sure what you mean by the upper control arm connecting to the sway bar, they don't bolt up together.
Bushing removal
Bushing removal
I should have just taken a pic in the first place...
I was messing around with it and there is no bushing there. I was looking at the washer in bad light. The reason there is slop from that bolt is when the guy installed the control arms he stripped the hell out of it and the nut is barely on.
Thanks guys.
Thanks guys.
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
