3rd gear grinds!!!
Old 11-09-2012, 10:34 PM
01C0bra
01C0bra's Avatar
Default 3rd gear grinds!!!
I just bought an 0 1cobra and the guy that I bought it from told me he had recently put in a stage 2 spec cluth in and after having it for a while, 3rd gear grinds above 2 rpm's when i change gears from 2nd tto 3rd. Any advice? Thanks
01C0bra is offline
Old 11-10-2012, 12:03 AM
01C0bra
01C0bra's Avatar
Another thing I noticed is that every time I put it in gear, I hear a popping noise, like the tranny ot something.
01C0bra is offline
Old 11-10-2012, 08:04 AM
BraMas
BraMas's Avatar
your syncros are shot! time for a rebuild
BraMas is offline
Old 11-10-2012, 09:29 AM
uberstang1
Chupacabra
uberstang1's Avatar
new trans time
uberstang1 is offline
Old 11-10-2012, 05:27 PM
01C0bra
01C0bra's Avatar
Could it possibly be the clutch cable? Cause it doesn't slip or anything, I can go from first gear to 5th anand it wont turn off on me.
01C0bra is offline
Old 11-10-2012, 05:56 PM
rygi23
rygi23's Avatar
clutch slippage and grinding come from two different causes, not related at all. You have a bad syncro. You can have a firewall adjuster installed and adjust it to where minimal clutch engagement is required, this may decrease the grinding a little but the bottom line is your going to need tranny rebuild so don't waste your money on anything else. If money's tight just drive her easy for a while.
rygi23 is offline
Old 11-11-2012, 05:49 AM
HeilmanMotorsports
HeilmanMotorsports's Avatar
Agree
HeilmanMotorsports is offline
Old 11-11-2012, 11:17 PM
TonyG
TonyG's Avatar
The grinding above 2k sounds weird. Maybe the cable tension isn't set correctly and the clutch isn't releasing completely. What pedal position does the clutch grab? Down low? Up high? If it's close to the floor, you may have found your problem. I would try some simple solutions first to be sure it needs a rebuild. I got rid of a grinding problem by just changing the fluid.
TonyG is offline
Old 11-12-2012, 02:55 AM
01C0bra
01C0bra's Avatar
Yeah I'm going to take it to my mechanic tomorrow to see whats the problem. Thanks
01C0bra is offline
caaraa
caaraa's Avatar
Great site. A lot of useful information here.
caaraa is offline
Quick Reply: 3rd gear grinds!!!
