Clutch cable adjuster
I have the stock clutch cable in my 01 cobra with a stage 2 spec clutch. Yeah I know this clutch i didn't buy, came with the car. But I was wondering if I had to actually buy an after market clutch cable to add an adjuster kit or can i bolt the adjuster right on?
What would be a good adjuster kit? thanks
i had a adjuster cable added to my stage two clutch, and it does wonders when your able to adjust the height of release, as far as brand to buy....its up to you....most adjuster are easy to install thru fire wall, placement is only concern, I would also replace the clutch Quadrant(located under dash) they sell kits for this, but it def upgrade from stock(stock can easily break, they are plastic, learned the hard way on this) you will notice def improvement in shfting smotheness, and if your racing, adjusting the pedal height can make all the difference......
breaking
10-02-2015 01:27 PM
junior04
09-28-2015 10:53 AM
