AUX input harness for Mach 460 hu
Trying to find a harness so I can hook up an iPod or phone to my factory mach 460 head unit. And I did search because it seems like this topic has been beaten to death but Crutchfield no longer carries the harness adapter that everyone recommends.
I came across a few here http://www.sonicelectronix.com/cat_f...ry-stereo.html but I'm not sure which will work because the the year ranges don't make sense.
Anyone have any ideas for a cheap solution? I don't care if it doesn't charge the device, just want to the ability to listen to an iPod or phone because my mach 460 disc changer is acting up, I keep getting the "CD Error" message, even after taking it out and removing the CD's.
Thanks guys.
Thanks guys.
After some more research I believe this is the one I need, I just don't want to spend $55 on it haha. http://www.sonicelectronix.com/item_...-AUX.html#tabs
Not trying to pick a fight, but I'm just curious.
This is the back panel of the earlier "stacked" unit:
Note that it is two "boxes" joined together. On this model the CD inputs were available at the rear panel connections.
This is the 2002+ model:
As you can see it is a single chassis, the CD inputs are not available at the connectors.
From the front they look the same...
