New to modding Mustangs!
I went with a freakshow performance one. I spoke to mike the owner at length about my setup which is forged block vortech v2 snow stage 2 patriot stage 2 heads and comp 268 cams. He recommended I go with a billet 3000-3200 stall. I had a 1800 edge unit in and it did not like the cams. I put this in and wow what a difference. If you want his number just pm me.
Do you plan on staying stock cams if so ill give you a sweet deal on my edge stall. Has maybe 1500 miles on it.
Welcome to Mustang Forums
i think 4.10s are good start, id compliment it with a tuner it would make your engine run to max and efficiently at that. look into a Upper Intake Plenum also.
http://www.americanmuscle.com/ac42v75thbop.html
maybe even a new cam
http://www.americanmuscle.com/mustan...s-xe262ah.html
id personally pass on nos..
I was looking at the information and with the upgraded cams is that a simple job. Can you drive it to get tuned or should it be towed. I am thinking of getting a super charger in my future but not right now.
Well here is the list I have right now, tell me if this is a good setup.
BBK 78mm T-body and plentum...http://www.cjponyparts.com/bbk-throt...-2004/p/IMCL9/
SCT X3 tuner...http://www.cjponyparts.com/sct-x3-po...-2013/p/XCAL3/
Mac underdrive pulleys....http://www.cjponyparts.com/mac-under...96-1998/p/UP3/
Rear Control arms....http://www.cjponyparts.com/rear-tubu...9-2004/p/RCK3/
BBK cold air intake and 4.10 gears are on the car already.
What you guys think???
But other than that, looks good.
inyadreems
08-21-2015 09:10 AM
08-12-2015 05:39 PM
