ABS kicking on for no reason.
Old 12-05-2012, 01:32 AM
Doyon
Doyon's Avatar
Default ABS kicking on for no reason.
Hey guys it's been a while. With no computer ill try to keep this short.
3 days ago my ABS light came on. It killed all power and could hardly maintain a speed of 20mph. Also my right turn signal (inside) stayed on and was green but not blinking. My right side drivers light and turn signal were off. This only happens if I'm stopped. I've made it go away by letting it sit and revving on it over and over then everything goes back to normal. Ill be taking it in tomorrow to have it looked at, but would really like some thoughts from you guys and if any of you had the same problems and how much it cost?
Thanks,
Josh
Doyon is offline
Old 03-14-2013, 02:06 PM
ledglow
ledglow's Avatar
Default Same problem
Thanks,
Josh
Hey josh my name is Daniel im having the same exact problem i dont know what it is if you have figured it out by now please let me know what it is and i will do the same !
Thanks for your time
ledglow is offline
Old 03-14-2013, 02:07 PM
ledglow
ledglow's Avatar
Im having the same problem it comes and goes im not sure what it is if you figure it out let me know and i will do the same thanks !
ledglow is offline
Old 03-14-2013, 09:10 PM
art02gt
art02gt's Avatar
My first thought is a loose or bad connection at a major ground. Cars will act possed when theres a open major ground. Let us know if u find the solution
art02gt is offline
Old 03-15-2013, 11:51 AM
ledglow
ledglow's Avatar
Iv done alot of research and all i have found out is that it could be a short circuit somewhere, also its not constant it only happens sometimes and usually if i let my car sit a while turned off it will fix itself and its good to go for a while but then it comes out of no where and anytime i give it gas it wants to die.
ledglow is offline
Old 03-16-2013, 09:10 PM
blu30val
blu30val's Avatar
Here's a post kinda related with info on abs. The problem this guy had was with traction control, but maybe it'll help
https://mustangforums.com/forum/4-6l...n-startup.html
blu30val is offline
Old 03-17-2013, 12:22 AM
SXGT
SXGT's Avatar
my 97 has an ABS OBD2 style output for diagnostics. IDK if yours will
SXGT is offline
Old 03-21-2013, 06:45 PM
blu30val
blu30val's Avatar
Any lucky?
blu30val is offline
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Florida Regional Chapter
09-30-2015 08:04 PM
ThatJuanStang
09-25-2015 08:01 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: ABS kicking on for no reason.
