Valve Train Noise
Valve Train Noise
I have a 2001 GT with a Vortec supercharger, bigger injectors, larger fuel pump, full exhaust, and a built ECU. There is a noice comming from the engine, almost sounds like a raddle or a grinding. Could it be the rockers comming loose? Or the lobs on the cam going flat? anybody have a problem like that, or know what could be causing it?
I had a noise like that once. Mine ended up being the timing chains were stretched out and loose. There were marks on my timing cover from the chain hitting it. Once I replaced the chains, chain guides, and chain tensioners the noise went away... It was a good time for a PI swap for me, too.
KingRando
10-02-2015 08:06 AM
