car wont start, theft light flashing, cant read DTCs
car had been running fine. then the other day i get in and try to start it and nothing. the theft light flashes brightly and quickly, the odometer is all dashes and no numbers. the first time i tried starting it the tac needle went all the way up and back down like all the needles do when you reset the computer.
on top of that when i try to read the DTCs my sct controller says it cant read the codes.
checked the fuses and underhood 20 was blown, i replaced it with no change
thinking maybe a PATS problem, any ways to fix that with out going to the dealer?
Fuse #20 in the battery junction box is the field coil power for the generator.
In the central junction box (under the dash) check fuses
- #2 (20 A, PCM power);
- #21 (5 A, instrument cluster and PCM volatile memory);
- #31 (10 A, data link [OBD2] connector).;
- #34 (20 A, instrument cluster power, CCRM and PATS transceiver);
Soldier GT
12
08-20-2015 09:42 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
