Brake issue
Old 01-10-2013, 10:11 AM
Trekev
Trekev's Avatar
Default Brake issue
Hello,
I recently replaced my rear rotors, pads, and calipers. However the calipers are not compressing the pads at all when I push on the brakes. The brake fluid line is properly connected and is bleed so there is no air in the line. The parking brake lines are not connected however. My question is are these necessary for the rear brake calipers to function? If not, any suggestions as to why the calipers are not working.
Thanks
Trekev is offline
Old 01-10-2013, 04:06 PM
LilRoush
LilRoush's Avatar
Rear calipers don't compress in. You need to turn them in. Use needle nose pliars or you can buy the 'special caliper tool' if you want.
LilRoush is offline
Old 01-10-2013, 06:17 PM
FlamingoGT
FlamingoGT's Avatar
Not that I can help him, but I think he is referring to the caliper pressing the pads to the rotors when he steps on the brake pedal, ie the normal brake operation.
FlamingoGT is offline
Old 01-10-2013, 08:46 PM
school boy
school boy's Avatar
there is a bleed valve on the mastercylinder, did you bleed this too? if air is trapped in there, it can cause this
school boy is offline
Old 01-11-2013, 08:53 AM
Trekev
Trekev's Avatar
Thanks, I'm going to bleed the MC. However, I can't seem to locate the bleed valves on the MC, any tips? Are they the things that are circled?
http://imgur.com/a/iFHz2
Thanks
Trekev is offline
Old 01-11-2013, 10:55 AM
school boy
school boy's Avatar
yours seem not to have them, my 2001 did. that is a pic of your car right?
Old 01-11-2013, 11:21 AM
Trekev
Trekev's Avatar
Yeah that's a pic of my 2000 mustang, its odd I don't have any bleed valves on the mc.
Trekev is offline
Old 01-11-2013, 06:54 PM
LilRoush
LilRoush's Avatar
Oooooh. It might be air in the line even after you bled them. It could also be old lines and they are stretching instead of forcing the fluid into the caliper.
LilRoush is offline
Old 01-12-2013, 07:15 PM
Trekev
Trekev's Avatar
I fixed the issue, the brake line was leaking where it connected to the caliper, just had to REALLY tighten them up. Rebleed everything and now my brakes work great Thanks for your help!
Trekev is offline
Old 01-13-2013, 03:01 AM
caaraa
caaraa's Avatar
You just saved me the trouble of reposting.
caaraa is offline
Quick Reply: Brake issue
