2004 Ford Mustang GT
Hello everyone,
I have a problem with my 2004 ford mustang gt, my passenger power window will not work when i press the window switch. Can someone tell me what the problem can be maybe motor, power switch. I havent check the relays because the drivers side working. If anyone can provide me some feedback. Thank you.
My driver's window stopped functioning suddenly with no warning. No noises, slowing down, etc. The switch is good (swapped it with the passenger switch on the driver's door). Then, a week later the driver's window started working.
Again, no noises, clicking grinding etc. I've read about the bushings or "plugs" failing in the window motors. Does this failure make a noise or cause slow/erratic movement? I haven't checked the wiring, but the rubber accordian sleeve around the wiring between the body and door is 100% intact.
Since the window was functioning perfectly before and after it stopped, am I correct in presuming the problem is either an intermitent connection or dead spot in the motor?
Can the motor itself be pulled out of the door or does the motor/regulator have to be removed as a unit?
It is the brushes in the motor that wear to the point they no longer make solid contact with the commutator--this is the problem for which banging the door often provides a temporary fix, as does as you discovered just driving around and normal vibration. It will not get any better and will in fact get worse--you need a new motor...
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
08-10-2015 01:44 PM
