Brake caliper replacement? Bleeding?
Old 02-14-2013, 04:25 AM
JC316
JC316's Avatar
Originally Posted by blu30val
I agree with chub. 2 man meathod works best for me. I'd recommend opening bleeder and pushing the pedal down, tighten bleeder and let pedal back up at least twice per wheel before pumping to speed it up. I don't know bleeding sequence off the top of my head.
I have a helper pump the brakes, then hold them down, then I crack the bleeder valve, then close the valve. Rinse and repeat till there are no air bubbles coming out.
JC316 is offline
Old 02-14-2013, 05:57 AM
Luke13
Luke13's Avatar
Originally Posted by Sonic Mustang
Vacuum bleeders suck. They are a pain. Instead, try a Motive Power Bleeder. It's like a hand pump bug sprayer with a brake reservoir cap on the end of the hose instead of a spray head.
Fill it with brake fluid, attach it to the reservoir, pump it to 12 psi (built in gauge) and bleed the brakes one at a time, master (if needed) RR, LR, RF, LF.
I mark a plastic soda bottle in 4 oz. increments and use it to drain the old brake fluid. That way, you keep track of how much fluid you've bled as you go along. There are only two mistakes you can make with a Motive Power Bleeder: Not attaching the cap properly before pumping up the bottle and running out of new brake fluid. If you run out of fluid, you'll pump air into your brake system and have to refill and re bleed.
This works better than having someone pump the brake pedal while you open and close the bleeders.
This method sounds like a good alternative to the vacuum method, and from a quick search would cost about the same as a decent vacuum bleeder. I don't mind spending the money ($30-$70) on equipment, because there's at least 3 cars in mind I'd like to change brake fluids in. That's one reason I'm looking for a one man system that works.
Luke13 is offline
Old 07-22-2015, 08:55 PM
fullmonte60
fullmonte60's Avatar
thanks jc316.
fullmonte60 is offline
Old 07-23-2015, 02:58 PM
Camster
Camster's Avatar
Originally Posted by Luke13
Same here!!! Most of my friends don't care much about car stuff, especially when it comes to maintenance. So I'm looking for a way to get it done alone.
Gee,I draft my sister for the project.Even she can follow "push"..."release".
Camster is offline
Old 07-25-2015, 08:52 PM
Ogre
Ogre's Avatar
Default Brake caliper replacement? Bleeding?
I have bled brakes on many cars over the years. I haven't tried the Motive bleeder because I'm not willing to pay that much for something that is not used often.
I made my own one man brake bleeder out of $2 worth of clear tubing and a water bottle. Very simple to make. I can tell you that by using this, I can get a better brake bleed than using a helper, a vacuum pump, or by using those brake bleeder's with the valve built in. I've tried them all.
Best of all, I can bleed brakes by myself which is faster than the other methods.
Ogre is offline
Granatelli Sales
01-20-2020 12:34 AM
JonnyBlazeGT
11-03-2015 01:10 AM
musnicki
09-23-2015 07:11 AM
cbird1177711
09-03-2015 08:43 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Brake caliper replacement? Bleeding?
