Help with unknown leak....
Old 02-19-2013, 11:56 PM
MidNightRunner
MidNightRunner's Avatar
Default Help with unknown leak....
Time to smog the car so I'm changing out the mid pipes today and noticed a horrible leak at the rear. As you can see in the first picture there is what seems to be differential oil on the mufflers. The 2nd picture was taken after I wiped off a thick layer of oil. Is it possible that were the drive shaft and the rear diff meet could have a leak? The red arrow in the last picture has a little bit of play, but I think that's normal.
My first guess was that the cover had a leak, but I didn't see anything.
Any ideas would be a great help!
Attached Thumbnails Help with unknown leak....-img_01.jpg   Help with unknown leak....-img_02.jpg   Help with unknown leak....-img_04c.jpg
MidNightRunner is offline
Old 02-20-2013, 12:42 AM
petrock
petrock's Avatar
Looks like the pinion seal is leaking, and the play is only normal if it is only a little bit and the play is not in the u-joint. Good luck...
petrock is offline
Old 02-20-2013, 01:10 AM
MidNightRunner
Looks like an easy swap so i'm going to give that a shot. Thanks for the advice Petrock.
Old 02-20-2013, 08:50 AM
BraMas
BraMas's Avatar
Make sure you google on how to change it. You have to put that pinion nut back at the correct torque or you ruin the crush sleeve
BraMas is offline
Old 02-20-2013, 09:17 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
It is not the torque of the pinion nut that is critical, but rather the torque required to turn over the differential, an indicator of the pinion bearing preload.
Here is the procedure, from the shop manual...
cliffyk is offline
Old 02-20-2013, 04:43 PM
MidNightRunner
Thanks for that link Cliffyk
Super_Chief
08-11-2015 03:54 AM
Kobra
04-08-2006 12:16 AM
203Mach1ne
02-28-2006 11:19 PM
Quick Reply: Help with unknown leak....
