1998 gt no acceleration
Vehicle: 1998 Ford Mustang GT (1FAFP42X0WF247201)
Calculated Owners: 3
Reported accidents: 0
This vehicle's AutoCheck Score: 50
08/31/1998 TX
Independent Source VEHICLE MANUFACTURED AND SHIPPED TO DEALER
12/31/1998 TX
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
01/14/1999 TX
Motor Vehicle Dept. TITLE (Title #:22031236163121232) (Lien Reported)
12/17/1999 TX
12/01/2000 TX
12/01/2001 AUSTIN, TX
12/20/2002 AUSTIN, TX
01/03/2003 AUSTIN, TX
45,590
Motor Vehicle Dept. TITLE (Title #:22731937608093538) (Lien Reported)
11/28/2003 LEWISVILLE, TX
67,049
Independent Emission Source PASSED EMISSION INSPECTION
12/02/2004 DALLAS, TX
12/03/2004 DALLAS, TX
12/13/2004 DALLAS, TX
75,870
Motor Vehicle Dept. TITLE (Title #:05746638321120527) (Lien Reported)
08/22/2005 DALLAS, TX
94,000
Motor Vehicle Dept. TITLE (Title #:05747238572143134) (Lien Reported)
REPOSSESSED
12/13/2005 DALLAS, TX
01/11/2006 DALLAS, TX
106,138
12/01/2006 DALLAS, TX
01/31/2007 DALLAS, TX
123,190
State Agency PASSED EMISSION INSPECTION
PASSED SAFETY INSPECTION
12/01/2007 DALLAS, TX
01/25/2008 DALLAS, TX
138,472
12/01/2008 DALLAS, TX
02/02/2009 DALLAS, TX
146,843
12/01/2009 DALLAS, TX
02/08/2010 DALLAS, TX
168,198
12/01/2010 DALLAS, TX
03/14/2011 DALLAS, TX
187,778
08/31/1998 TX
12/31/1998 TX
01/14/1999 TX
12/17/1999 TX
12/01/2000 TX
45,590
67,049
75,870
94,000
REPOSSESSED
106,138
123,190
138,472
146,843
168,198
187,778
my first thought was buy a 99, lol then i kinda felt like an ***! haha anyway, id start with simple, free and work your way up. So id take out the plugs and see what they look like for starters, if they are worn, or burnt, or wet. that will tell you a lot of information and give you a place to start. if they dont look normal, use that information to start tracking down why, like wet might indicate bad spark, white, might indicate fueling issues, ect.
Change plugs,wires, coil packs, fuel filter, bank1 o2 sensors clean IAC and MAF and see what u got. For what u paid for the car I would just buy all that stuff considering its probably been abused or neglected for someone to let it go that cheap.
Update on the issue i have changed plugs, coil packs, cleaned sensors, fixed some vacuum leaks, removed exhaust to verify cats are flowing.still same issue i know i have Trans issue but u can here it when rev it in park its just ten time worse even i engage the Trans into drive i get a egr and when i rev it the rpms come down slow. I'm going to get into the tps and throttle body next and check egr.check manifold for cracks.. I don't see any Sparks at night from wires.was also thinking fuel filter and pressure test.
After doing research i think this p1757 code is causing my issues song with solenoid codes.its all electrical issues in the Trans so could cause the car to run like **** if the computer is telling it too start in od I'm guessing
In the 8 pin connector on passenger side Trans said i should have 9 volts on number one terminal i show no voltage and when i look at the plug the copper female slip on isn't there but i see then on 2 thru 8 is there supposed to be one on #1 i would think so if u are supposed to have voltage there
AmericanMuscle4.6GT
11-10-2015 02:06 PM
mrappe
09-26-2015 10:16 AM
Offendant
09-23-2015 07:21 PM
09-08-2015 11:50 AM
zanemoseley
09-06-2015 12:58 PM
