help
help
ok so i just put new spark plugs in the car 2 of them failed, so i fix that. put on a bbk 70mm T/B and trickflo neck. now im blowing off egr lins and my car is not running right. i think the catalytic converter mite be clogged. just can find whats rong no CEL. put scaner on the odb port and nuthing......
dont have the power i was makeing be for the spark plug went bad. some one help me
this guy is haveing the same problem,
So the hose fell off again last weekend while I was showing the car to my sister. The hose seems to fall when I put the car under heavy acceleration. That leads me to think its an issue with the exhaust creating pressure and making the hose falling off.
One of the things I looked at with a friend this weekend, is that the car doesn't have any mufflers. It seems to have 2" pipes and still has its cats. It sounds great inside the cabin, and it doesn't sound bad outside either. The sound get a little off when you hear it under acceleration on the outside.
My gut feeling at the moment is to get 2.5" pipes, drop the cats, and put in a set of mufflers (likely flowmasters because I like the loud obnoxious sound). I think this would maybe fix the issue with the EGR, plus leave my car with a better all around exhaust system. I don't understand why someone would remove the mufflers and leave the cats.
Anyway, the question is if you guys have any opinions or suggestions on what I should do or why you think my EGR hose keeps popping off. Thanks!
