Mustang won't idle
Mustang won't idle
Hey guys - so the past couple months I've been having some problems with my 2002 Mustang GT idling. (I have done a number of searches on here, and tried a couple things I found, with no improvement).
So this all started with it sounding like a French horn while idling - indicative of a failing IAC. So I replaced the IAC with one I bought at O'Reilly's auto parts. After replacing the old faulty one, and clearing my KAM, my car would idle around 1k - not good, but no more French horn under my hood. I went back to O'Reilly's and exchanged it for a new IAC, thinking that the new one may have been a little faulty itself. The second new IAC, however, still idled at 1k - so in an attempt to put a bandaid on the situation (so I could get to work) I put a copper pipe cap in the vacuum line leading to the IAC to restrict the air flow, so the idle would be at the right spot. Note - with the pipe cap, I cant use the A/C or defroster, as the idle would dip to sub 500 because the IAC would not compensate for it. Next, I replaced the TPS and cleaned the MAF in hopes that it would idle correctly - but no improvement was seen with these. I also checked the vacuum lines, and as far as I can tell they're fine.
Now it runs fine with the copper pipe cap bandaid - but I'd still prefer to fix it completely before summer, so I can use the AC. Do you guys have any idea what the problem may be at this point? I would rather avoid taking it to a mechanic, since I have no other way to get to work. Sorry about this being a little wordy, I just wanted to provide all the info I could (my mods are in my sig as well).
Thanks in advance!
Thanks in advance!
So let me get this straight, you capped the vacuum line that controls the IAC and the car idles normal. Correct? Then you have a vacuum leak somewhere between the throttle body & cylinders. Otherwise the car would stall. Its probably the throttle plate not fully closing or an upper/lower intake manifold leak. Good luck...
KEM Motorworks
08-14-2015 10:13 PM
