18% overdrive crank pulley
Old 04-07-2013, 07:02 PM
97stanger
97stanger's Avatar
Default 18% overdrive crank pulley
I'm currently running an IW 10% overdrive crank pulley, 8 rib setup, Thump tensioner and 2.85 blower pulley and see roughly 19-20psi. I can get a good deal on an 18% overdrive crank pulley. I am still running my '97 timing cover. I have done some research on the 18% overdrive and am seeing different answers/results. Does anybody run this piece first hand and what type of modifications had to be made? Is it a must to run an electric water pump? I'm also considering going with the 2.7 blower pulley if I swap to the 18% overdrive and I can imagine I would pick up another 5psi minimum with some decent power gains. Just looking for some input on those of you who know/have installed the IW 18% overdrive crank pulley. Thanks guys
97stanger is offline
Old 04-08-2013, 06:30 PM
97stanger
97stanger's Avatar
ttt, anybody have experience?
Old 04-08-2013, 06:36 PM
uberstang1
Chupacabra
uberstang1's Avatar
I can tell ya for sure an 18% od crank pulley wouldn't fit on my car with my water pump or my crankshaft sensor, I had to grind off some of it for the 10%, an 18% i wouldn't be able to grind without ruining the cover, this is on a 3 bolt 97 cobra timing cover though.Thats a small blower pulley, thats the one thing about the vortechs is the lower step up ratio causing to run smaller blower pulleys and fighting with belt slip.
uberstang1 is offline
Old 04-09-2013, 02:16 PM
TCStangerv6
TCStangerv6's Avatar
I told you already. You don't need to run an electric water pump.
here is my 18% on m car. All I did was lathe some of the lips off the water pump at work.
as for the crank shaft sensor. I grind some of that off too. This was on a 3 bolt tensioner cover. I'll get pictures of that later. Everything works fine on my car.
TCStangerv6 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
spdeplayer2
10-24-2015 09:45 AM
svfetter
10-05-2015 11:39 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: 18% overdrive crank pulley
