hydroboost problem
hydroboost problem
OK so I changed the hydro boost because it was leaking threw the brake pedal and I put the new one on and I had to take off a side block or piece that only the old one had because Ford says its a obsolete part. Anybody change this part only piece and bolt u have to take off the old hudroboost. The bolt also has a hole threw the end for the fluid and a o ring at the top of the bolt. Where the rubber hose goes on that's the part
i did put that piece onto the new unit and thats where its leaking from, do you know where i can purchase that piece from then? i think on the side facing the hydroboost i might be missing a o ring???
Not sure where you can get that block. If it is leaking from that large bolt that holds it onto the hydroboost then get a new o ring. Mine came with all the o rings.
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
