Battery draw
Old 04-22-2013, 07:12 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Default Battery draw
So out of the blue my 02 GT started acting up. The alternator is putting out between 13.8-14.2V so that's looking good.
The battery is just over a year old and takes a charge just fine but I am getting some significant arching when I connect the terminals to the battery posts and by significant I mean a lot more than usual so there is a draw somewhere.
I checked all the stupid stuff I could think of but found nothing. I left the battery in the car last night, fully charged and this morning when I started it up it barely had enough juice.
I'm scratching my *** and blinking at this point so does anybody have any ideas where to start to look for my gremlin?
Thanks.
fastbackford351 is offline
Old 04-22-2013, 08:13 AM
chillindamost
chillindamost's Avatar
Do you have the mach 1000 stereo? My vert top leaks and I have a draw from my amps getting wet. If you pull the fuse for the mach amps you can see if the draw goes away. The other common draw is if a diode in the alternator fries you will get a draw. I am sure others will pipe up, but that is my situation.
chillindamost is offline
Old 04-22-2013, 06:51 PM
fastbackford351
Foghorn Leghorn
Thanks.
Old 04-23-2013, 03:12 AM
petrock
petrock's Avatar
Here is a very easy step by step instructions on how to pin point a parasitic battery drain like yours. http://www.wikihow.com/Find-a-Parasitic-Battery-Drain. You can pick up a multi-meter at most auto parts stores or radio shack or electronics store for under $30. You don’t need a hyper accurate meter like a Fluke meter. Just something that can read below 50 milli-amps (0.05 amps), which most can.
petrock is offline
Old 04-23-2013, 06:24 AM
fastbackford351
Foghorn Leghorn
Great link.
Old 04-23-2013, 12:15 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
One note, it can take our cars 40 to 45 minutes to "go to sleep"...
cliffyk is offline
BOB ROME
07-26-2023 01:54 PM
4cylinderplus2
10-09-2020 07:45 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
logan409
09-26-2015 07:43 PM
uedlose
09-10-2015 01:37 PM
Quick Reply: Battery draw
