Re-Painting Mach 1 Calipers
Old 04-26-2013, 12:36 PM
WhiteFaleen2001
WhiteFaleen2001's Avatar
Default Re-Painting Mach 1 Calipers
How would I go about repainting my Mach 1 Calipers? Would I want to sand the paint off or use some sort of thinner? Has anyone done this before? Thanks!
Edit. I will be using caliper paint and NOT powdercoating.
WhiteFaleen2001 is offline
Old 04-26-2013, 02:04 PM
Sonic Mustang
Banned
Sonic Mustang's Avatar
Painting calipers is no different than anything else. Surface prep is everything. The caliper must be clean and free of flaking paint before applying new paint.
I've cleaned calipers with brake cleaner and all purpose cleaner and degreaser. If needed, you can followup with a wire brush but make sure you clean off everything the wire brush loosens. Whenever I use a degreaser or brake cleaner, i follow up with all purpose cleaner and then make sure I rinse/wipe any cleaner residue off the surface.
Keep cleaners away from rubber seals and boots and carefully mask off anything that shouldn't have paint on it.
I've all ways removed calipers from the car to paint. I can't see how guys paint them in place.
You might want to read the directions for whatever brand of paint you're using.
Sonic Mustang is offline
1BAD3V
Tennessee Regional Chapter
10-06-2016 12:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Sixer4Life
09-29-2015 07:03 PM
1BAD3V
Indiana Regional Section
09-26-2015 09:03 AM
Quick Reply: Re-Painting Mach 1 Calipers
