How to increase my hp?? - MustangForums.com
Old 04-28-2013, 05:05 PM   #1
timritchieblue
timritchieblue's Avatar
Default How to increase my hp??
I'm currently running a vortech v1 set at 9psi. I'm still draw through. If I bought the CX RACING intercooler kit, and converted to blow through, what else would I need to do?? I'm at 360 whp right now..would like to see 450ish?
timritchieblue is offline   Reply With Quote
Old 04-28-2013, 05:19 PM   #2
LilRoush
LilRoush's Avatar
What have you done for heads/cams?
LilRoush is offline   Reply With Quote
Old 04-28-2013, 05:22 PM   #3
timritchieblue
Stock heads and cams, with mild porting Typhoon intake with 38lb injectors
Old 04-28-2013, 05:34 PM   #4
SXGT
SXGT's Avatar
can you pully swap for more booost ?
SXGT is offline   Reply With Quote
Old 04-28-2013, 05:40 PM   #5
timritchieblue
I'm using the 3.11 pulley right now, what size pulley can I use? If I get a power pipe, blow through and intercooler 42lb injectors and new tune, what hp would I be approx? My bottom end is support to be good for 650hp
My bro's car is a 95 with a N/A DSS 331 with same gear, and he pulls on me hard..and hes planing on bolting on NOS??
Old 04-28-2013, 05:50 PM   #6
dwtjr3
get a Intercooler first then worry about pulley swaps,
Invest in a good intrercooler tho like a treadstone so you dont need to change intercoolers down the road.
After that you can go down to a 3.00 inch pulley and run a 10% overdrive pulley and you should be over 500 at that point
or keep your 3.11 and get a 10% OD pulley and be closer to 500 rwhp instead of over it.
I am stock internals and a 3.33 inch pulley running 11psi with a power pipe and I put down 400 rwhp thru a auto trans just to give you a reference point.
dwtjr3 is offline   Reply With Quote
Old 04-28-2013, 06:09 PM   #7
timritchieblue
Well I'm trying to save on the tunes, my tuner is over a hour away, so I try not to make to many trips their. For a blow through system I'll have to drop off car anyway. So with pulley (s) intercooler, blow through, And injectors I could go over 500? Im using a 340 focus pump.
Old 04-29-2013, 08:40 AM   #8
dwtjr3
I think that you could be at 500 with a pulley change but at that point in time your are going to need a new fuel pump setup so you may want to keep it dialed down some untill you get a fuel system.
Old 04-29-2013, 08:46 PM   #9
jam23r1
jam23r1's Avatar
not to steal your thread. but I am looking to get more HP too and was looking for some advice. this is what I got so far vortech supercharger.V-1 70mm TB, bigger injectors 38#, Borla Cat back exhaust. BBK shorty headers, BBK O/R X pipe
what would you guys do next looking for a good 400+HP
jam23r1 is offline   Reply With Quote
Old 04-30-2013, 12:33 PM   #10
97stanger
I would do a nice intercooler and try to get more boost out of that blower. Your heads/cams are for sure a restriction, but for just 450-500rwhp goal you don't even have to touch them. Have you considered meth? shot of nitrous? both?
97stanger is offline   Reply With Quote
Bought a new 15 GT annnnd it's messed up. 2k232 The New S550 2015-2017 Mustang 3 09-16-2015 11:28 AM
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 01:08 PM
Time for a new clutch? MasterLanMan 4.6L (1996-2004 Modular) Mustang 6 09-13-2015 09:21 PM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
How to increase Lateral Gs in 2015 GT? mungodrums Suspension 0 09-07-2015 08:30 PM
