A/c is not working
A/c is not working
My ac is not working. The compressor is not engaging I checked the pressure but read 0 psi that I'm assuming is from the compressor not turning on. Is there a way to overide the low pressure switch or anything else to help diagnose what could be the issue
If the system is dead flat, as it sounds it is, and has been that way for a long time (several months) then you should evacuate it fully using a vacuum pump. This will also reveal any significant leaks.
HF has a nice 2.5 cfm vacuum pump for $120 (on sale now for $105) that costs less than what most shops will charge to evacuate the system. I have had one for years that still works like a champ--got it back when they were $60...
