A/c is not working
Old 04-30-2013, 07:49 PM
Jtsullivan
Jtsullivan's Avatar
Default A/c is not working
My ac is not working. The compressor is not engaging I checked the pressure but read 0 psi that I'm assuming is from the compressor not turning on. Is there a way to overide the low pressure switch or anything else to help diagnose what could be the issue
Jtsullivan is offline
Old 04-30-2013, 08:58 PM
SXGT
SXGT's Avatar
did this happen all of a sudden or has it never worked.
SXGT is offline
Old 04-30-2013, 09:14 PM
FrostByte
FrostByte's Avatar
0 psi on suction gauge w/o compressor running means your out of refrigerant. The compressor wont cut in until about 35 psi.
FrostByte is offline
Old 05-01-2013, 03:45 AM
Jtsullivan
Jtsullivan's Avatar
Yeah it's been that way ill try adding some refrigerant and see what happens
Old 05-01-2013, 09:41 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
If the system is dead flat, as it sounds it is, and has been that way for a long time (several months) then you should evacuate it fully using a vacuum pump. This will also reveal any significant leaks.
HF has a nice 2.5 cfm vacuum pump for $120 (on sale now for $105) that costs less than what most shops will charge to evacuate the system. I have had one for years that still works like a champ--got it back when they were $60...
cliffyk is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
FivePointToTheOh
10-02-2015 04:09 PM
Pyrate Dave
09-10-2015 07:30 PM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: A/c is not working
