New Edge Owner!
Old 05-07-2013, 08:09 PM
86HOGT
86HOGT's Avatar
Default New Edge Owner!
Hey Guys,
Long time Fox owner (10 years).
I just picked up a really rough 00 GT for dirt cheap. I mean cheap!
It has what I believe a collapsed lifter. I got to hear the engine run, and it got itself on the trailer. It's definitely an upper end noise judging by the sound and frequency. Passenger side rear head.
I've worked on a lot of cars, built the engine myself in my 86.
I almost want to just get another long block and swap it since I have a lot of other work to do to the front end, but if changing the lifters(if that's the case) in the car is do able, I'd be all for it. Can you do it without pulling the timing cover or no dice there?
Thanks!
86HOGT is offline
Old 05-07-2013, 08:30 PM
'02gtgarrett
'02gtgarrett's Avatar
Looks like you got yourself a fun little project! Have FUN WITH IT!
'02gtgarrett is offline
Old 05-08-2013, 06:12 AM
Solar
Solar's Avatar
Wish I could answer your question but I do not know much on engine work. Either way, I hope you get your answer and good luck.
Solar is offline
Old 05-08-2013, 07:06 AM
Vertigo_GT
Vertigo_GT's Avatar
Originally Posted by 86HOGT
Hey Guys,
Thanks!
Welcome to the modular Mustang world. It won't be the lifters because the modular engines dont have them. Check out the Tech articles and how to's. Great stuff in there to get aquainted with the breed. With your experience you should be able to get this pony into top shape. Good luck. Looking forward to watching your progress.
Vertigo_GT is offline
Old 05-08-2013, 07:32 AM
Solar
Solar's Avatar
And I knew that. I failed.
Solar is offline
Old 05-08-2013, 07:59 AM
Vertigo_GT
Vertigo_GT's Avatar
Lol. I haven't turned a wrench under the hood other than to change a battery in over 20 years. I just follow along on build threads and remember that fact about the OHC engines.
OP HAS A NICE FOX TOO!
Old 05-08-2013, 09:28 PM
ZeroTX
ZeroTX's Avatar
You can get a set of those heads in good shape, cams and all, usually for $200 or less, so if nothing else, just swap the heads. If you're handy, then it should just be the cost of gaskets (maybe bolts? Not sure of they're TTY or can be reused).
If it's more than that, any 2v 4.6L should be a relatively easy swap. If it's a 2000 with original engine, then it's a Windsor 4.6L, which isn't as common as the Romeo, but a Romeo swap isn't a big deal either. The Romeo 4.6L 2v was used in the Crown Vic through 2011. Lots of 2007/8's on the used market. Bolt on the Mustang accessories and such, and anything that doesn't fit from your Windsor, get it from a 2001-2004 Mustang.
ZeroTX is offline
Old 05-08-2013, 09:52 PM
JC316
JC316's Avatar
Congrats. The lash adjusters are stupid easy to change. Just take the valve cover off, rotate the cam so the valve is closed, then pop the rocker arm off with a screwdriver. See here:
JC316 is offline
Old 05-09-2013, 04:18 PM
86HOGT
86HOGT's Avatar
Yeah that's what I meant. The lash adjusters! They look similar to a lifter!
Thanks guys!
86HOGT is offline
Old 05-09-2013, 04:43 PM
My02convertible
My02convertible's Avatar
would it be the same on a SOHC instead of DOHC?
My02convertible is offline
Quick Reply: New Edge Owner!
