Steering Bushings - need help - MustangForums.com
Old 05-13-2013, 09:47 AM   #1
rocket22
Default Steering Bushings - need help
As summer is here the wife is bit....complaining that she doesnt get to drive the cobra due to the looseness, floating of the steering. It really isnt bad, but I want to fix.
The steering tends to drift a little, but when you go over tracks or bumps it really feels floating, which has led me to believe that it is the steering rack bushings.
Honestly I have been repairing my cars for the past 20 years and have never had to replace steering bushings, it has been control arms, tie rods, and ball joints.
I have read a number of treads on the site and am checking to see if anyone has the following,
The best way to diagnose this is the issue.
The 1997 cobra (115k miles) is stock, not driven hard. Any recommendations on parts?
Has anyone had luck with the $15 Amercian Muscle standard bushings? (not being cheap, just am planning on ordering floor mats from them and was going to add this in).
ANy links to good videos would help. DOes the steering need to be disconnected?
rocket22 is offline   Reply With Quote
Old 05-13-2013, 01:40 PM   #2
Seabee1993
Honestly, I have no idea what you mean. You have inner and outer tie rod, spindle, which connects to the ball joint, which is pressed into the lower comtrol arm which attaches to the k member.. The back of the spindle ties into the strut.
Doing my best to figure out what you are trying to replace. The floating feeling could just be bad struts, as it will undulate more than one time over a bump.
Seabee1993 is offline   Reply With Quote
Old 05-13-2013, 01:42 PM   #3
Seabee1993
Rock Auto will be your best bet for parts BTW.
Old 05-13-2013, 02:03 PM   #4
rocket22
Default steering rack bushings
I am looking for a good DIY for a 1997. I would like a video if possible. My concern is the steering disconnect.
I have seen two instructions, one says remove steering linkage (tie rods) and drop the steering rack, the other does not.
I figure at 100K for $20 it makes sense to replace the rubber with Poly, and I am betting some of the play will be reduced.
Old 05-13-2013, 02:35 PM   #5
Fillerdust
Fillerdust's Avatar
Yes get some poly ones for a couple bucks more. Best $20 I spent, and made a world of improvement in my 110k gt. I undid the tierods from the knuckle, steering shaft bolt and the rack studs itself and dropped the whole thing. You don't need to undo the power steering lines, you will have enough slack to drop it to swap the bushings.
Fillerdust is offline   Reply With Quote
Old 05-15-2013, 08:57 AM   #6
rocket22
Default Did you replace anything else while tie rods off?
how did you lock the steering wheel? Was the steering linkage seperated?
Old 05-15-2013, 10:25 AM   #7
BabyGT
BabyGT's Avatar
Replaced my rack bushing on a 94, which should be the same rack, I just unbolted the rack from the subframe and left everything connected.
BabyGT is offline   Reply With Quote
Old 05-15-2013, 10:42 PM   #8
uberstang1
Chupacabra
uberstang1's Avatar
Its a peice of cake to change rack busings, and if there bad enough to cause symptoms you are describing it should be fairly easy to notice there bad.
uberstang1 is offline   Reply With Quote
Old 05-16-2013, 09:19 PM   #9
art02gt
art02gt's Avatar
Quote:
I tried to reply to your pm, but it says your inbox is full. anyway, no, I didn't have to remove the wheels. I just lifted the front of the car enough to where I could work comfortably (use jack stands). you don't have to lock the steering wheel since the linkage only connects one way, but if it makes you feel better, tape or tie it and keep the front wheels straight. you don't have to disconnect the linkage, just make sue you don't force anything. I disconnected it just to be safe, I really didn't want to fix a problem and cause another.
art02gt is offline   Reply With Quote
Old 05-16-2013, 09:51 PM   #10
rocket22
Thanks all, parts ordered and install scheduled for next week. Can I use ramps or should use jack stands?
Street Action Tonight Explosive Street/Strip 17 10-02-2015 08:45 AM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 05:55 AM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
Hi - Yes, I'm a gal and need help CS2007 General Tech 7 09-29-2015 08:38 PM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
