blown valve cover gasket 02 4.6
Old 05-13-2013, 10:08 AM
Shelton Coker
Shelton Coker's Avatar
Default blown valve cover gasket 02 4.6
What will cause a valve cover gasket to blow out? The engine has no oil pressure. I think the pump went bad.
Shelton Coker is offline
Old 05-14-2013, 10:40 PM
art02gt
art02gt's Avatar
Overtightening is the most common cause since they are plastic. And gaskets do go out eventually, some sooner than others. Afterall, the car is 13 years old.
art02gt is offline
Old 05-15-2013, 09:44 PM
uberstang1
Chupacabra
uberstang1's Avatar
If the engine doesn't have oil pressure , its not from a bad valve cover gasket you have alot bigger problems.
uberstang1 is offline
Old 05-15-2013, 11:27 PM
art02gt
art02gt's Avatar
no kidding, it didn't even cross my mind that he was relating the two.
art02gt is offline
Old 05-18-2013, 11:08 AM
86HOGT
86HOGT's Avatar
The only reason a gasket that's not under oil pressure is "blowing out" would be excessive crankcase pressure.
86HOGT is offline
Old 05-29-2013, 10:30 AM
Shelton Coker
I have been working on the 02 gt. I found that one bolt was missing on divers side. 2 yrs ago The car had to be worked on again by a good mechanic due to a major screw up by an idiot who tried to put in a heli coil and caused more damage.
GimpyHSHS
19
12-19-2023 01:12 PM
Dathan
10-05-2015 05:52 AM
winner99
10-01-2015 01:06 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: blown valve cover gasket 02 4.6
