Mustang mystery problem???? - MustangForums.com
Old 05-18-2013, 08:34 AM   #1
Dragonus18
Default Mustang mystery problem????
Ok. A strange thing happened the other day. I was driving down the street and it started to rain which is no big deal. It wasn't raining hard and there weren't any big puddles on the road. On my way home the started to jerking as I was about 30-40mph a little on the hard side. I called my tuner up (who is also a mechanic) and told him what happened when I crawled it home and he had me check my MAF (which was unreachable since it was in the right fender and I just installed an Anderson power pipe ) and then plug in my Predator handheld. No CEL light were on so he had me do some checking around in the Predator and than told me to check my coils and my fuel rails. He also had me unplug a electronic device in the middle of the fuel rail that was attached to a hose and told me to turn the car in the on position because fuel would shoot out of there when I did for a second but when I did nothing happened. As of yesterday the problem just happen to go away and the car is now running fine!? This has me baffled. I know this might be a tough one to crack but if anyone might have a clue as to what happened I would be very grateful. Thanks always guys!!!
Dragonus18 is offline   Reply With Quote
Old 05-18-2013, 06:04 PM   #2
FlamingoGT
A shot in the dark, but maybe the fuel pump going bad? Or something not so serious and easier to fix maybe a clogged fuel filter?
FlamingoGT is offline   Reply With Quote
Old 05-18-2013, 06:17 PM   #3
Dragonus18
I just got a fuel system done. I doubt it but what else can it be?
Old 05-19-2013, 01:24 AM   #4
jjstandardz
Quote:
Sounds the exact same as what happened to my mustang. One (or most likely more) of the coil on plugs are going bad, or the boots are worn out/leaking. My car used to sputter real bad and miss when i would hit puddles or drive in the rain or anything like that. I could not figure it out it would just go away after a day (water dries up).
After a while the COPS will short out and it will always do it though, i just replaced all of mine with accel aftermarket ones and it runs like brand new.
jjstandardz is offline   Reply With Quote
Old 05-19-2013, 10:02 AM   #5
Dragonus18
Do they go bad after a certain amount of miles or a certain amount of time? I just had my block built and the motor has almost its first 1,000 miles. I have originally 57,000 miles on the odometer. I barely drive this thing.
Old 05-20-2013, 08:58 PM   #6
Dragonus18
bump!
Old 05-21-2013, 06:41 PM   #7
Stevo86
Mileage is irrelevant. Your car is 10 years old, rubber cracks. Simple check is to pull them out and look at them.
Stevo86 is offline   Reply With Quote
Old 05-21-2013, 07:56 PM   #8
Dragonus18
Quote:
I'm guessing just check and see if they're cracked or worn out? Is it an expensive fix to replace them? Never did this before.
Old 05-21-2013, 08:13 PM   #9
Seabee1993
Three bucks a piece for new boots isn't that big of an investment. Coils will essentially last forever, if you get them wet, or feed them after midnight.
Joking aside I think it's every 30/50k you should consider replacing the boots.
Seabee1993 is offline   Reply With Quote
Old 05-22-2013, 12:10 AM   #10
Dragonus18
Ok. Thanks for telling me. I had no idea. That's a tiny fix. I should try that one for sure. Other than that is there anything else that maybe comes to mind?
Brake Problem FD725 4.6L V8 Technical Discussions 3 08-23-2015 07:43 AM
Alternator problem? jjwinel78 V6 (1994-2004) Mustangs 1 08-17-2015 04:34 PM
1989 starting problems, engine won't turn over. KEM Motorworks 5.0L (1979-1995) Mustang 20 08-14-2015 11:13 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
tail lights problem philster0306 2005-2014 Mustangs 1 08-10-2015 12:33 PM
