putting gears in, do i need a limited slip additive
Old 05-20-2013, 08:40 PM
david2450
david2450's Avatar
Default putting gears in, do i need a limited slip additive
I'm putting 4.10 gears in an got some valveoline 80-90w that the Haynes manual called for, do I need to put a additive in also?
david2450 is offline
Old 05-20-2013, 08:58 PM
Darkhorse04GT
Darkhorse04GT's Avatar
If you have a limited slip, yes you need the additive. Otherwise the clutches will engage during normal turns causing the rear axle to attempt to drive straight ahead.
Darkhorse04GT is offline
Old 05-21-2013, 12:04 AM
FrostByte
FrostByte's Avatar
Some oils come width additive in it already. Read the label to be sure.
FrostByte is offline
Old 05-21-2013, 07:38 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Most synthetic gear oils are sufficiently "slippery" that f/m additive is not needed--as Frostbite said, "read the label". Too much friction modifier, or f/m added to synthetic oil, will make the LSD clutches slip too much and not lock up as they should...
cliffyk is offline
drfister
05-03-2018 10:38 PM
musnicki
09-23-2015 07:11 AM
5.0 kevo
09-03-2015 06:24 PM
CarrieS
09-01-2015 01:00 PM
gus_vb
08-29-2015 11:35 PM
Quick Reply: putting gears in, do i need a limited slip additive
