OEM 5spd Shifter Question (Lube or Replace)
Old 05-21-2013, 10:56 AM
Smorphine
Smorphine's Avatar
Default OEM 5spd Shifter Question (Lube or Replace)
(1996 Mustang GT) My shifter has lost it's loving feeling recently. Doesn't spring like before. No gear grinding just a little sluggish. How do I re-grease/lube/rebuild or should I think about replacing it with an aftermarket one?
Thanks in advance!
Smorphine is offline
Old 05-21-2013, 12:33 PM
DricePhotog
DricePhotog's Avatar
Thanks in advance!
Good question. I am looking to replace mine as well.
Posted from MustangForums.com App for Android
DricePhotog is offline
Old 05-21-2013, 05:34 PM
Stevo86
Stevo86's Avatar
If it doesn't spring odds are the springs inside are worn out. I would just go with an aftermarket replacement.
Stevo86 is offline
Old 05-23-2013, 03:19 PM
antwaan
antwaan's Avatar
yeah I'd get an aftermarket one. It was the first mod I did to mine several years back and it was worth it.
antwaan is offline
Old 05-23-2013, 09:40 PM
stevednmc
stevednmc's Avatar
Go here: http://www.mgwltd.com/mustang_shifter.shtml Buy it. Don't look back!
stevednmc is offline
Old 06-14-2013, 10:38 AM
JonChaka96GT
JonChaka96GT's Avatar
Idk of its a little late, but id have to suggest getting an after matket shifter. I recently replaced my stock shifter with a SR Performance short throw shifter from AmericanMuscle.com and its shifts amazing. way better. not as sloppy and gears go on great. It's not even that pricey and easy to do it your self. took me about 30-45 min. Hope this helps if your still looking...
JonChaka96GT is offline
CMcNam
10-30-2022 11:40 PM
Urambo Tauro
12-17-2016 03:30 PM
CubanoGT
10-02-2015 10:29 AM
unit91
08-31-2015 10:27 AM
mweiland
08-13-2015 05:11 PM
Quick Reply: OEM 5spd Shifter Question (Lube or Replace)
