Newer motor question?
Hi Guys,
I have a 1996 GT with 190,000 miles on it and its getting tired. I was going to just do the PI swap but I met a guy who has a short block out of 2003 GT with 90,000 miles on it and he said I could have it for $350. He took it out to replaced it with a crate motor because he installed a kenne bell SC and knew that it was only a matter of time before the original would give way. It says it ran perfect and there are no problems with it. My question is if I should buy some new main bearings and rod bearings and throw them in there while I have the short block out of the car? It's as easy as and pulling the old bearings putting lots of assembly lube on them and re-tourqing them correct? Thanks for your time guys
It's way more than just replacing them. You'd have to polish your crank and a few more things. But those motors last a while, if you where to replace the main bearings i would just do a complete over haul since it would be apart already.
Luke9222
10-22-2015 11:55 PM
