98 GT Oil Pressure drops
Old 06-10-2013, 09:37 PM
Dubwhat
Dubwhat's Avatar
Default 98 GT Oil Pressure drops
Haven't posted here in a very long time. Sorry guys.
So I noticed that when I am driving my car, when I'm in 4th gear and pulling off the accelerator, that my oil pressure gauge bounces all over the place. When at idle its perfectly fine.
I also noticed that in park, if I rev it to 5500 rpm, the gauge starts to back off. Is this normal? Could it be the sender thats going out? Am I starting to see engine wear issues?
Supposedly this engine only has 40k on it. Its from a 2002 Crown vic...so I dunno if that is causing any problems...
Help wmburns...your our only hope...
Dubwhat is offline
Old 06-11-2013, 07:32 AM
1998Slow 'Stang
1998Slow 'Stang's Avatar
The gauge in the dash is a dummy gauge. It doesn't do a thing. I'd buy an aftermarket oil pressure gauge and let the one in the dash do it's thing and not worry about it.
1998Slow 'Stang is offline
Old 06-11-2013, 11:25 AM
Dubwhat
Dubwhat's Avatar
I don't notice any weird performance, but am worried that something internal might be going....
Dubwhat is offline
Old 06-11-2013, 01:08 PM
1998Slow 'Stang
Let me reword what I said previously as I feel it was a little confusing. I believe that your stock oil pressure sensor is going bad; they are quite prone to failure. Ford dropped the ball with the instrument cluster on these cars in my opinion, as the oil pressure is not a switch and merely a replacement for a low oil pressure light. It says everything is normal above 6psi and you have nothing below if it is below 6psi. When the switch for the gauge begins to fail it could act as yours is.
If you are truly worried about it buy yourself a decent electric oil pressure gauge from American Muscle or someplace like that, heck, even the Sunpro stuff they sell at autozone would be an upgrade.
If you have ramps or a jack/jack stands and some very basic hand tools you can install it in an hour tops, taking your time of course.
Old 06-11-2013, 01:35 PM
uberstang1
Chupacabra
uberstang1's Avatar
The gauge and or sender is bad, the stock oil pressure gauge is a dummy gauge and stays in one location. It only drops if the motor drops below 8psi of oil pressure, and if that was happening it would be at idle not on the gas. Normal oil pressure on an aftermarket gauge should be a warm idle of 30-40psi, then on the gas itll move up to 80-95psi.
uberstang1 is offline
Old 06-11-2013, 06:19 PM
Dubwhat
Dubwhat's Avatar
Wow, What a wealth. I do have jacks and ramps but no real place to do much work at this point. I will look into a different gauge but don't you have to tap for it?
Dubwhat is offline
Old 06-11-2013, 06:36 PM
uberstang1
Chupacabra
uberstang1's Avatar
Not sure about the 2vs but my 4v had an extra port below the factory sender port, u can also use the factory port or use a t connections ad run both.
svfetter
10-05-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
wraith777
09-28-2015 10:49 AM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: 98 GT Oil Pressure drops
