03 GT Steering Popping/Binding/Creaking when warmed up (NOT Rack Bushings)
Old 06-13-2013, 11:09 AM
The02GT
The02GT's Avatar
Default 03 GT Steering Popping/Binding/Creaking when warmed up (NOT Rack Bushings)
Rack bushings have been changed, recent alignment, ball joings have NO play, tie rods have NO play, new PS fluid, car ONLY does this crap once I have been driving for 20+ mins and at lower speeds (under ~20 MPH) while turning, even turning slightly the steering wheel pops and has a slight bind to it, pops/binds in both directions all the way throughout the turning range. At a loss on what it could be, it does not do it when the car is cold, the longer I drive it the worse it gets till it cools off again...
The02GT is offline
Old 06-13-2013, 01:32 PM
uberstang1
Chupacabra
uberstang1's Avatar
Considering u changed everything the only other suspect would be the rack itself.
uberstang1 is offline
Old 06-26-2013, 10:48 AM
The02GT
The02GT's Avatar
Just for future reference incase someone else has the same issue all it ended up being was a simple power steering fluid change mulitiple times over a few days using Mercon V transmission fluid, I put normal power steering fluid in a couple months back and guess it was not good enough.
The02GT is offline
Old 06-28-2013, 01:45 AM
MidNightRunner
MidNightRunner's Avatar
Thanks for the update. I'm going to try changing the fluid since I am in the same boat.
MidNightRunner is offline
CS2007
06-25-2019 09:45 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
allenmaty
09-24-2015 09:17 AM
Quick Reply: 03 GT Steering Popping/Binding/Creaking when warmed up (NOT Rack Bushings)
