steering rack install?
Old 06-20-2013, 08:02 AM
jjstandardz
jjstandardz's Avatar
Default steering rack install?
Do you guys know of any guides or write ups for replacing the steering rack and pinion alongwith the outer tie rods?
Also should I order my replacement from napa ( rebuilt by a1 cardone, heard some sketchy things) or oreilys (acdelco)
Thanks!
jjstandardz is offline
Old 06-20-2013, 06:28 PM
supersnake67
supersnake67's Avatar
It's not hard the 2 outer castle nuts 2 bolts that hold the rack, I believe a 13mm bolt for the steering shaft only pain is starting the lines for the power steering. Don't forget to replace the Teflon o rings. I had a factory rack blow out the left inner tie rod seal so I went to AutoZone and got a duralast rack well...... 3 racks later I finally got 1 that isn't leaking??? All blew out the inner seals. It's a crap shoot I guess.
supersnake67 is offline
Old 06-20-2013, 07:02 PM
art02gt
art02gt's Avatar
it's a piece of cake. just undo the 2 mounting bolts, 2 power steering lines and the steering linkage (1 bolt). tie rods are pretty straight forward. drain the reservoir before you start
art02gt is offline
Old 06-20-2013, 07:34 PM
jjstandardz
alright thanks guys, do i need any special tools to clamp the lines or anthing, or should i be good after i drain the fluid?
Old 06-21-2013, 07:04 AM
supersnake67
They are hard lines down by the rack so you can't pinch the lines off. And gravity will let the lines drain out when you unscrew them. I believe I found taking the top line off first to be easier then take the bottom line off. Good luck. Lay your old rack on the ground and match it to your new rack end to end and count the threads for the jam nut before you transfer them to the new rack. Helps get the rack close so the alignment wont be way out of wack.
Old 06-21-2013, 08:12 AM
jjstandardz
Awesome thanks! I think I might start this project on sunday or wait till I have another day off next friday ill let ya guys know how it goes
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
Blk Vert
09-09-2015 12:16 PM
09-08-2015 11:50 AM
Quick Reply: steering rack install?
