stock H-pipe won't come out...feeling defeated - Page 2 - MustangForums.com
Old 06-23-2013, 01:54 PM   #11
8111870a
First time I needed the stock h-pipe removed, I brought it to a muffler shop just to break the bolts loose. It cost me a cup of coffee and a dozen donuts. Did the same thing first time I needed to loosen the axle nut on wifes Mazda. (No air tools at that time)
8111870a is offline   Reply With Quote
Old 06-24-2013, 10:35 AM   #12
built67
hey guys, thanks for all of the help! gave it a second shot with my buddy and we got it to come out. Soaked it with pb blaster and then used a half inch ratchet with half inch extensions, then a reducer to 3/8s with a swivel and a 15mm deep socket...once we broke the nuts loose we then used a 7/8s open end wrench to remove the O2s and just let them hang outta the way...this is MUCH easier than reaching up on top of the bell housing to disconnect the harness (your forearms and wrists will hate you if you try that method).
I know that these motors have a slight tick bc of the timing chain tensioners but i cant tell if i have a slight exhause leak or its just the pipe amplifing everything...if i put it on ramps and run the car and get under it will i be able to tell? or should i just bring it to a muffler shop now that the pipe is on. Under acceleration at low rpms i hear a ticking but i cant really tell what it is...i dont hear a ticking at idle tho
built67 is offline   Reply With Quote
Tune with a stock air box mapitts 5.0L GT S550 Tech 49 05-15-2016 03:57 AM
Cam and rear end gear questions Ryan Fitzpatrick New Member Area 3 09-14-2015 03:21 AM
85 5.0 with stock holley calif. carb tramphardrocker 5.0L (1979-1995) Mustang 6 09-13-2015 09:56 PM
The First Month GentleBen Members Rides and Car Show Section 3 09-11-2015 06:34 AM
2007 mustang gt vs 2012 mustang v6 Webster454 2005-2014 Mustangs 1 09-07-2015 05:59 AM
