HELP! Middle of pinion seal change problem!
Old 07-16-2013, 03:42 PM
MidNightRunner
MidNightRunner's Avatar
Angry HELP! Middle of pinion seal change problem!
I just took off the drive-shaft and I put on the torque wretch and the pinion nut has no resistance! I can spin the pinion by the nut with my fingers. What is going on?
Did the guy who installed my gears screw up the crush sleeve, or is this a sign something else?
Can I just use these values that Cliffyk posted in an old thread?
"The pinion nut is to be tightened to whatever torque is required so that it takes 16-29 lb-in of torque (with new bearings/gears/etc) to rotate the pinion gear."
"For reusing the bearings and crush sleeve (8 to 14 lb-in)"
Please help!!!!
MidNightRunner is offline
Old 07-17-2013, 09:34 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
It is a sign that the pinion nut was not properly tightened. A lot of mechanics (apparently including the "guy" who installed your gears) feel that all they have to do is mark the nut, and/or count the number of turns, and then replace the nut to the same position--I have even seen this put forth in some online "how-to" articles and threads.
It is not so.
Here is the proper procedure for replace the pinion seal, and re-tightening the nut...
cliffyk is offline
djbigskrilla
09-20-2022 01:04 AM
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
SteelerNation82
09-09-2015 09:06 AM
Urambo Tauro
09-07-2015 12:47 PM
91StangOwner
08-20-2015 11:34 PM
Quick Reply: HELP! Middle of pinion seal change problem!
