Tools
Sometimes nuts and buts get mixed around, but first if the 10mm is loose, try the 9 mm. If thats too small try a standard size socket instead like a 3/8" socket, a 7/16", or a 13/32". You dont want to use an air compressor to get these off as they might snap the bolts off. You also dont want to overtighten as its really easy to strip the threads on the transmission. You REALLY dont want to use an air compressor/impact wrench if the socket is already loose, then you will just strip the head...When you put the pan back on, purchase a new oil pan gasket as well as a new trasmission filter, along with new transmission fluid. My guess is yours wont be bright red and will probably need to be replaced. You will want to scrape the old gasket off of the pan with a razor blade too if theres any residue left. I think the torque specs are really low, like 12 ft lbs. If you dont have a torque wrench, just hand tighten them all in then with a 1/4 socket wrench tighten it with only pushing with one finger, dont push on it too hard otherwise it will strip. If it leaks, tighten each bolt 1/4 turn on the pan and try again. DONT STRIP IT, otherwise you will have to helicoil the threads which is a pain in the butt.
TfcCDR
09-14-2015 12:08 PM
